90.4....................
I think that only an insecure inspector would take offense if asked politely for a code reference. Most inspectors would be more than happy to give you a code reference and how they interpret it.
Why would politely asking the inspector for a code reference have negative consequences?
I have never understood inspectors that get upset when asked for a code reference.
Chris
A few times I have made the change and then showed the inspector or his boss why I didn't need to, either with code references or code columns from EC or ECM magazines.
I don't know if this is a good idea or whether or not I'll do it again.
I like to argue but sometimes I make more money if I don't.
one of mine too. I immediately think that I'm dealing with either an incompetent or lazy inspector.
That is one of my big pet peeves. I get real irate when I hear an inspector say "Ah 90.4, you have to do what I say."
Chris
That's just one more reason to climb the food chain. Everyone has a supervisor for a reason.My premonition is that I would be subjected to punitive inspections from this inspector -- whose inspections are already a well above average ordeal to begin with.
....... climb the food chain. ...........
Shouldn't that be chain of command?
Food chain sounds so........ deadly.
Looking for a local code will not help matters - There is not local code for GFCI protection of lighting anywhere in the bathroom....
IMO - Be firm! But very aware... California code states that no switching may be within 5' of the shower or tub... That is a code.... It gets chucked in there every cycle by Cal-OSHA I beleive... Allowing the location by use of a GFCI - might work in your favor here...
I have had many inspector call for GFCI protected lighting - and they start rattling off that it is in the code - I immediately challenge them to find it - which they swear it exists 'somewhere'.... Then I say look - "If you want it GFCI protected - please 'request it' in writing on a correction notice so I can submit it with my change order." BUT - if you're gonna bust 'em on the inspector - you had better make sure roses spout from every opening on the job. And if in my neck of the woods that may mean somethings that may be more mind blowing as some of them are actually written down... Like each 2-wire circuit being in the pigment of the phase it is on (not re-identified...) - meaning you might have to go find some red/white 12/2 NM cable.... Just try that out....Choose your battles...
Hmmm...it seems like this 5 foot rule applies strictly to 'bathtubs', but could it be that a bathroom that has a shower without a separate drip pan be classified as a shower room? And therefore no switches at all should've been installed there? Would the sink basin and toilet be technically within the shower room?
The job was finaled today so this is academic.
California Electrical Code
404.8(A)(2) [OSHPD 1, 2 & 4] Switches shall not be installed within shower rooms or stalls or be accessible from within these areas. Switches shall not be installed within 5 feet (1.52 m) of the perimeter of bathtubs.
Thanks for your input, BTW. I was hoping to get your opinion all along. It's why I bumped the thread a few times.
Did you PM me on it before? I don't hit every thread - but if I see SF or CA in the title I'll usually drop in...
So which of the zany clan did you get? (initials?) Some are more reasonable than others? Since you got a correction notice on it - I can assume one of the 3 more zany of the dozen or so. And can also assume it was an enlightening experience?
And yes - I have had to put all bath switching outside in the hall for some smaller baths because of this - makes customers really happy to have someone decide this for them.
Rather than trash someone in public - I'll PM you....C. R***
Enlightening experience. Yep. I'll need to think about adding dollars to any project when CR's district comes up. Except - they all decided to play musical districts again right in the middle of this project. Rough inspection was with R.M.
Of course, this isn't the first time I've come up with the "adding dollars" concept. For some reason I never follow through with it.
PS) Yep, I PMd you on this.
