mivey
And should not be a problem if the right epoxy is used. A lot of folks fear epoxy because they are used to using some cheap junk that does turn loose....but the epoxy was quicker and didn't leave unused holes.
Also, I'm open for any better ideas you have?? I am fully aware that most anything can be done to some higher level if one has all the special tools and materials needed. That is not always the case and we sometimes have to use what we have on hand. And when working against deadlines, we don't always have the time to run out for materials or reinvent the wheel.
But controlling the oxygen is the trick isn't it? A weld does a great job of that if done correctly. If done poorly, a weld will come loose also.Even the finest domestic or imported epoxy only has the same chance of sticking to metal as paint does. Once a few layers of metal atoms decide to become involved on an intimate basis with a few stray oxygen molecules the epoxy will have nothing left to stick to.
Drill it or Dremel it, same as I would if I had a rusted or corroded factory bolt that had me locked out.So now you have a nut spinning around inside the panel where you can't get to it and the screw is rusted to the nut.
How do you gain access to the inside of the panel now?
But controlling the oxygen is the trick isn't it? A weld does a great job of that if done correctly. If done poorly, a weld will come loose also.Drill it or Dremel it, same as I would if I had a rusted or corroded factory bolt that had me locked out.
On a panel: more than a handful, less than a hundred or so. On other type boxes: Too many to even fathom a guess. In the old days, we did not have a Dremel with us so it was drill or grind and pop the head off with lineman's and a screwdriver or chisel.Now we are on the same page.
Oxygen can be controlled. The use of products such as LocTite anti-seize is great for such an application. NoAlOx works well in a pinch.
I am curious. You say 'if' you had a rusted or corroded factory bolt that could not be removed. How many times have you had that happen? I ask because I personally have never seen such a thing. I have seen myriads of poor replacements that have failed and needed to be cut or ground into submission but never had a factory fastener that required such additional persuasion.
To qualify the above, by the time (years and years) that a factory fastener would get corroded to the point of uselessness, most of the factory fasteners have been long since lost and replaced with whatever was nearby at the time.
Yeah, but they don't allow any of that metal/oxygen intimacy on the factory floor nowadays.They glue metal auto body parts on now.
Contray to Bob's take on this - I guess? Someone gave him grief about self-tappers for the fear of a hot drill bit going in to find some wire to melt into, or drill into? For those reasons I too would stay away from Tek screws - but nothing in the code about it either....
That was a great ace to pull out of the sleeve. There are probably still some inspectors here in de-fib. :grin:When the panel arived the cover was already installed using Teks.
