billsnuff
- East of 480sparky
You can take this any way you wish, but you removed the cover...
Was there a warning label on the cover ?
If so, what did it say ?
If the cover had no warning information, then there is no indication of the level of hazard you are dealing with, so how do you know what level of PPE to use or if it even exists?
restricted and prohibited approach for cantact is 'avoid contact' table 130.2(C) 2009 and from 130.7(C)(9) voltage testing live parts is HRC 2* with volt rated glove and insulated tools and the proper CAT rated meter.
So without the warning label information and without a copy of 70E you basically had no clue of the type or level of hazard you were dealing with.
I with the inspector........
