transman2
- Brooklet,Ga.
I have a few questions.
1. Does equipment have to be on a disconnect that has the same AIC rating or higher as the Panel circuit breaker?
2. If an appliance such as an wall mounted exhaust fan comes with an cord/plug, is it leagal by code to cut the plug off and hard wire it?
3. Is it legal by code to use switches, receptacles/plugs or breakers as a means of disconnect for various pieces of equipment such as fixed exhaust fans, fixed space heaters, wall mounted emergency lights, mini split ac units.
Thanks,
Thanks,
