ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
Allow me to pick a very small nit. The term "average" here is a bit of a misnomer. You can't really average a time varying quantity over time; calculating an average involves adding a bunch of quantitative values and then dividing by the number of terms, but in the case of a continuous function there are an infinite number of points. That leads to infinity terms in both the divisor and dividend. What we have to do is calculate the integral of the function over the period between t1 and t2.Actually, I should have said for a circuit with resistance an reactance. You will find that I??R peaks at the same time as current, not at the same time as voltage as on Post #229. If you insist on treating real power as a variable with time, then I think plotting I??R would be the thing to plot.
Personally, I consider real power to be the average of instantaneous power, so it really has no meaning except when considered for a particular period of time like a full cycle. I think plotting it as a function of time has no utility.
As you were...
