Your still not getting it. You wrote....again you are wrong with 1W/VA
You have not completed what you want to proof continue your equation
cosx = Watt/VA = (I * V) / (I * V) = 1
here all unit cancels each other and nothing remains.
you are thinking it as acceleration formula = v (velocity)/t(time) = v/sec but it is not like this nor it is a constant to have a unit.
Did you not read it completely that I have proved it in previous post
V* I * cosx ( represents real power) = V* I ( represents apparent power) ; now we will write it like this
p.f = cosx = ( V * I ) / ( V * I ) = 1 -----------2 no unit
you see we got pure value without any W/V-A. That is why I am saying we can not put W/V-A in our equation like Eq.1 which is written by you.
For one, you cannot have cos(φ) on only one side of the equation. It should be...cosx = (I * V * cosx) / (I * V) = ???
..and two, you are starting with a unitless ratio by itself on one side of the equation. This is a ploy to force the value on the other side of the equation to also equal a unitless ratio. It cannot be done without manipulating the terms, thus making it invalid.More succinctly, it should be...
Power Factor = Watts/Volt-amperes = (V * I * cos(φ)) / (V * I) = cos(φ) * 1 Watt/VA
