LarryFine
- Henrico County, VA
- Electrical Contractor
Watts, power.Smart$,
what does the red letter represent in above formula?
(I know that much.
Watts, power.
(I know that much.)
Yes, the formula is correct. It is watt but I just asked about the letter W. He has shown with W and W also represents the Work. It should be represented by P not W :grin:
The equation is poorly written and vague.
Depending on the units of V and I, the unit of power may be a milliwatt, kilowatt, megawatt, etc.
Formulas should be written with symbols for the electrical quantities not the units of measure.
Units should be included when evaluating the formula. e.g.
P = 120V * 10A * 0.9 = 1080W = 1.08KW
Agreed. Yet I did not write the formula. It is copied from a text.Yes, the formula is correct. It is watt but I just asked about the letter W. He has shown with W and W also represents the Work. It should be represented by P not W :grin:
Agreed. Yet I did not write the formula. It is written as such in many texts.
If you're going to include units, should you not also include power factor (pf or PF)?...
I believe he was referring to a half-cycle of power, which would be a more accurate description, since voltage and current are, in a theoretical context, 90? out of phase with each other.Must nit-pick a bit. Energy flows into the cap for a quarter cycle, then energy flows back to the source in the next quarter cycle. That is the exchange occurs at the rate of 2wt and is sinusoidal.
Good man.Yes, sir. A constant one watt produced for one second and a consistent one watt consumed for one second. The produced power is one watt. The consumed power is one watt. These are instantaneous values as well as average values.
Well this is where the straw broke the camel's back....Good man.
The instantaneous value of power is instantaneous voltage times instantaneous current.
Still with this?
I don't know... but we'll find out before longDo threads automatically close after 400 replies?
My point was about the instantaneous power.Well this is where the straw broke the camel's back....
If your question is limited to our hypothetical one watt-second produced and consumed scenario, then the answer is yes.
If not, the answer is dependent on whether any part of the instantaneous product is VAR (volt-amperes reactive). If there is no VAR present, then the answer is also yes. If there is VAR present, the answer is no.
Granted it is a unitless value in most usage forms, but in truth it does represent the ratio watts/volt-amperes and thus yields the appropriate units to the result.
The instantaneous product of current and voltage is the power at that instant. I don't know why you would reject that. VAR is irrelevant in terms instantaneous values.
Yes, if you include units in the formula (or calculaiton therewith), units not of the result must cancel within the calculation.Smart$:
Can you please make it a little bit clear saying " Yields the appropriate units to the result"
If I am not wrong, you mean it is only for unit cancellation. Am I right?
The unit cacels each other and we get proper unit ( W, V-A, Var)units not of the result must cancel within the calculation
It is power at that instant. No representative about it.Yes, volts times amperes is representive of power present at that instant,
