- Lockport, IL
- Retired Electrical Engineer
Trouble maker!. . . consider this: A 6' long by 2' deep counter centered against a 12' wall. It too would be open on three sides, so could it be called a penninsula?
How about another obsevation to throw into the mix.:grin: The code does not define a "what" a penninsula is. If you think of a land penninsula as a "body of land surounded on three sides by water" and apply that logic to a countertop, then you could say a penninsula countertop is a countertop that is open on three sides. Since the code does not say that a penninsula countertop is one who's long dimension is perpendicular to the wall or another counter space then consider this: A 6' long by 2' deep counter centered against a 12' wall. It too would be open on three sides, so could it be called a penninsula? I don't know.
As many have said, this area is gray. I think with the wording in the code as it is, I think some good judgement should be applied.
You can use any color elephant's tail except green or white. :grin:It would be like asking me to use the NEC to prove to you specifically that we cannot use the tail of pink elephants as a fuse.
Again, I can't prove specifically that's because the code assume nobody is making up imaginary lines
You shouldn't resist- we need the humor. Your humor actually makes for a good point as to the need for a good definition of peninsula. I have enjoyed the challenge of this article. I will continue to do as I think should be done at least until the code clarifies it.I know, but I simply could not resist.![]()
I am starting to take offense to your comments that appear to be direct toward me. I understand your point but you think there is no other was to see this and you are wrong. You have no idea what the cmp's were thinking on this. My concept may be what they had in mind- I don't know but it surely makes sense to me. I don't knock your thinking on this as I actually see it quite clearly. I agree a stand alone cabinet perpendicular to the wall should be a peninsula. I am just not convinced the CMP's see it that way.
In my eyes it makes logical sense to include a recep. in both scenarios since there is the same amount of counter being covered. Personally I don't care if you don't install one in either case. In fact, it looks like in 2011 we won't need one in either scenario for peninsula's under 6'.
Now where are they measuring it from???? Here we go again.![]()
Actually, I think there are three views in this thread:Looks like there are two views for the stand alone peninsula space.
#1 It's just one space so you only need one receptacle.
#2 It's two spaces, a wall space, connected in a straight line with a peninsula space.That peninsula space being the area which extends beyond what a normal counter depth would be.
I vote #2
Why, from "the connecting edge", of course.Now where are they measuring it from???? Here we go again.![]()
That means you rarely have to make this decision. That leaves more time to have fun here.Honestly- I rarely come across a cabinet that is installed alone and perpendicular to the wall.
I say that 1a or b would be adequate. The peninsula needs one receptacle, unless it's effectively divided, which can be in either place.Since there is nothing in the NEC that defines the maximum depth of a wall space, and since 210.52(C)(3) states that a peninsular countertop is measured from the connecting edge, and since there is no connecting edge in the scenario under discussion, I find myself agreeing with electricmanscott (#1b).
Derek, I think most of the members would agree with that but not with the stand alone peninsula. My point is that they are changing definitions between the two situations. In one case they agree we measure to the base cabinets - 2' out and in the other case they measure to the wall-- that is the issue I have with it. You can't change the rules.
We'll see what others say unless they are burnt out on this. :grin:
Not at all. In that figure, there is no "stand alone peninsula." The peninsula it shows is attached to a set of wall cabinets. So for the moment, Mike is simply voting "present."It seems like some other fella thinks like Dennis does:
I, at least, am not attempting to. I am applying 210.52(C)(1) to countertops on top of base cabinets attached to walls, and I am applying 210.52(C)(3) to countertops on top of peninsulas. And what exactly is a peninsula? That is the center of this discussion. For my part, if it looks like a duck, and walks like a duck, and talks like a duck, then I am going to say it would taste good with a nice white wine sauce,You can't change the rules.
Okay so since when did that matter when using the NEC. Again consistency is what I think the NEC is looking for here. Adding more cabinets on the wall to create an "L" shape should do nothing to change how we look at that piece in question.Charlie B said:OK, so I will reveal the basis of my beliefs. For the "stand alone peninsula," you wish to assign the first 24 inches from the wall to the world of 210.52(C)(1). But consider this: the homeowner cannot use that section in the same way they would use the "normal" countertop space. They can't get to it. They can't stand 25 inches from the wall, with the countertop space between their body and the wall. Therefore, it simply does not look, walk, or talk like a duck. Q.E.D.
And if the refrigerator in the figure were moved 6" to the left, so the righthand peninsula countertop edge is a straight line to the wall, the peninsular receptacle is no longer required? But if we move the refrigerator only 5" to the left, so there is a 1" jog in that righthand peninsula countertop edge, the peninsular receptacle is still required?Not at all. In that figure, there is no "stand alone peninsula." The peninsula it shows is attached to a set of wall cabinets.
Cheers, Wayne
