LarryFine
 - Henrico County, VA
 - Electrical Contractor
No, that peninsula abuts a wall-cabinet countertop, and the dotted line is clearly definable.
An ell of a slice?Okay, slice the 6" ell off on the right and it is what?
Cna't y'all jsut amdit you'er wrnog.An ell of a slice?![]()
If we thought we was, we would.Cna't y'all jsut amdit you'er wrnog.![]()
I knew you wouldn't concede but I'll post it anyway. :grin:
I just now see what Derek was getting at. That is even more convincing. Lop of the 6" of cabinet leave the fridge and what do you say?
Hey Derek you convinced me. :grin:
That's funny, you convinced me when you pointed out the double standard people were using in measuring cabinets.:grin:
At one point people are saying its the edge of a connecting cabinet and then they are saying it is the wall.:-?
But, becuz we ain't, we ain't.![]()
Maybe ya ain't, but IMHO, yessum ya is.:grin: Y'all picken 2 different demarkation points .
In both those instances you just mentioned, only one receptacle is needed for the penninsula.
The NEC clearly defines where they seperate.
The NEC does not make us "seperate" again,,,if there is ONLY a penninsula there. You can't take a requirement from (2) seperate items (1) being a countertop and (1) being a penninsula,,,,then bundle them together and "apply" them to (1) single penninsula item,,,the NEC doesn't work that way no matter how mant different pictures you post.
In the picture I posted, is the section (B) a counter top or a pennisula?
There is no demarcation point recognized by the NEC. Why should you think there is?At least ours is an NEC recognoized demarcation point,,,,,no body on your side can even agree on where this "imaginary line" should be drawn.
Since I cannot stand at the location of the letter "s" in "peninsula," and from that location do any work at the counter space between that location and the back wall, then I do not consider the space between that location and the back wall to constitute a 210.52(C)(1) area. You have a 210.52(C)(3) space, and that is all you have. The NEC does not define the terms associated with this discussion, so we must go to industry standards or to Websters, whatever we can find. If you say "kitchen countertop" to almost everyone in the country, the thing they are going to envision is a space that would give them the ability to stand where I described, and to use that countertop space from that location.
By that logic, in the original configuration with the 6" ell, there is no wall receptacle required, because there is only a 6" wall countertop space, and 210.52(C)(1) only requires a receptacle for a wall countertop space that is 12" or wider. Is that your position?Since I cannot stand at the location of the letter "s" in "peninsula," and from that location do any work at the counter space between that location and the back wall, then I do not consider the space between that location and the back wall to constitute a 210.52(C)(1) area.
It is clear that the adjoining edge is where the peninsula touches the base cabinet. It does not call the wall the adjoining edge.Definately the wrong word,,,but I was copying jumpers post,,,,,The NEC clearly talks of the adjoining edge, never mentions a line as they try to imply
You can stand on the other side besides you cannot stand in front of the base cabinet has nothing to do with the situation. Everyone seems to agrees that a second recep is needed on the peninsula when there is an adjoining counter. You cannot stand there either.Since I cannot stand at the location of the letter "s" in "peninsula," and from that location do any work at the counter space between that location and the back wall, then I do not consider the space between that location and the back wall to constitute a 210.52(C)(1) area. You have a 210.52(C)(3) space, and that is all you have. The NEC does not define the terms associated with this discussion, so we must go to industry standards or to Websters, whatever we can find. If you say "kitchen countertop" to almost everyone in the country, the thing they are going to envision is a space that would give them the ability to stand where I described, and to use that countertop space from that location.
