chris kennedy
- Miami Fla.
- Retired electrician
chriss: it is just a joke hope to not mind it :grin:
All in good fun my friend. Now back to the topic at hand.
What was the topic???
The point here is that we have instantaneous information for a time period equal to or exceeding one cycle of voltage (or current, or two 'cycles' of power). So the correct statement would be instantaneous current times instantaneous voltage is instantaneous apparent power at every instance, for we know from the collective information there is an out-of-phase relationship between current and voltage.Instantaneous current times instantaneous voltage is the power at that instant. Nothing more. Just power. It doesn't come in different flavors. It is just power.
We are not discussing v(t)/i(t) here. We are discussing v(t)?i(t) where t has a range of at least one cycle. No one is contending that the v?i product is not expressed in units of a watt.Smart$:
Let me add some informtion. Since rattus explained v(t) / i(t) equals to a constant number same for reactive. So, Constant number is a real number same as Resistive and dut to voltage divided by current as a general it is called watt for an instantaneous power for an instant of time.
Not a problem by me, as long as you don't try to correct me for using VA.sorry for mistake, I meant just consider it v(t)*i(t) for power but it is still not look good for me to call it VA. I know it does not make any difference here saying watt or VA but I feel like this to say watt.
Is that even possible? :grin:...as long as you don't try to correct me...
Sure... trying is possibleIs that even possible? :grin:
I can do bothCan you throw a potato chip? Can you bend a cracker? If so, then maybe so!
Not a problem by me, as long as you don't try to correct me for using VA.![]()
Not precisely...Time period and instantaneous is contradiction in terms.
There is no point to discussing this aspect until you accept the premise I described above.Instantaneous current and isntantaneous voltage is instantaneous real power at every instance. Out of phase only exist in TIME.
Not precisely...
A more precise statement is time period and an instant are a contradiction in terms.
Let's say we have two sets of values representing exclusive instances of a mutual event: v1 and i1, and v2 and i2. The 1's correlate with each other as being values of one instant in time, as does the 2's being of another instance in time. However, all four are instantaneous values with time being involved, as they cannot be of the same instant in time.
There is no [ultimate] rule or law that says we cannot evaluate multiple instants in time, and the proper descriptive term (adjective) for the instantaneous values at different times is still "instantaneous".
I couldn't agree more, but yet you seem to be hypocritical in this regardThere is not point in discussing anything on a false premise.
Nope.So the correct statement would be instantaneous current times instantaneous voltage is instantaneous apparent power
Nope.
Just power.
Back at it againNope.
Just power.
On what throne does or did the person that said we had to use instantaneous measures of the same instant sit? Perhaps he sits in your bathroom?Unless, unless, unless, unless, unless, unless, unless, unless, unless, unless, unless, unless, unless, .........V1 and I2 is involved AND the T1-T2 equals the phase shift between V and I.
Of course those are NOT an instantaneous measurements in the SAME instant. Humpty-Dumpty weould be preoud!
