 - Massachusetts
Two-way radios and a footswitch make it easy for one person at the pulling end.
One guy can do it, I still have put two there for safety.
No one seems concerned about burning the PVC with the rope on the second 90, so I guess it isn't a potential for a failure. I know several guys here talk about using metal 90s on long pulls with lots of heavy wire in them.
Now heres another trick when you pull your rope lets say you have a 2 " or a 3 " conduit take a smaller size sealtite strip off the outer jacket sealtite flex cut it about 3 foot slide it over rope install it inside the 90 side your pulling from put a few tie wire wraps around the sealtite let her rip! You will not burn thur your 90!
I'm picturing a conduit system installed a month or so ago, we come back and blow in a string, pull in the pulling rope, and ....... I just can't figure out how I install this sealtite jacket into the 90, and where does the tie wrap go?![]()
Well lets say your pulling into a switchboard or a panel pvc comes in from grade below into bottom of can or swb .
The conduit is stubbed up into switchboard or panel can slide the smaller sealtite flex with out jacket into conduit stub up tie wire it to the floor wrap it with tie wire around the top duck tape it .
It doesnt move its just a glide for the rope to protect the pvc from burning by the rope . the pressure is applied to the pvc wall as the rope presses it outward it only moves when the head comes out . some times we dont even tie wire it one guy holds it in place its not a issue .
Were not installing the jacket we take it off were using the metal part of the sealtite it slides in better then with jacket is on !
AH, thanks for clearing that up for me. I'm a bit slow sometimes.
one to operate tugger, and one to pull rope off of tugger.
Being a dumb engineer and all that, I have often wondered why these kind of things are not broken up into shorter chunks to make it easier to pull. It would seem to be a whole lot simpler to pull this in 2 chunks, maybe starting at each end, and connecting at a jbox in the middle somewhere.
It would seem to reduce the risk of something going really bad by a lot, as well as reducing the labor.
Don't quit your inside job
Setting up is half the battle so just keep tugging.
Pre lube the PVC 90's and/or the string/rope and they will not burn in.
