That allows you to have just bulb A on, or bulbs A and B on, but not just bulb B on.I've never done it but I think it could be done with 2 diodes and a double pole switch. Both bulbs paralleled and but one bulb has a diode in series so it just runs on DC.
What the craps going on my first post wasn't there a while ago?
Here is the basic idea of floor lamp switches http://www.juddley.com/3_way_lamp_logic.htm
Thanks Satcom
I been looking for ideas for a science fair for younger kids that I have been asked to do this summer
Sorry ,got a phone con before I could finish and edit.Here's the corrected version.:grin:
Satcom your example shows more than 2 wires that was a requirement in OP description
If you look at this diagram of Ron's, and alter it by placing a third diode in series with the other switch, but in the opposite polarity, and placing a fourth diode in series with the other bulb, also in the opposite polarity, the two bulbs will switch independently, each from its own switch, as if the other bulb and switch didn't exist.Would you post up a schematic of a double pole switch,one diode and 2 wires going out to the fixture that has two lights,,,,,,,,,,
Thats right
And you'd think we havn't gained anything. But if you replace the bulbs with motor starter coils you could control two motors with two wires and use a 2 pole switch as a selector switch.![]()
Ron,
If you drive DC coils from rectified ac,
then you would be applying 60 Hz pulses (120/2),
then you might cause contactor chatter.
If you drive AC coils from rectified ac,
then chatter should be a real problem.
Comments ?
