jetlag
- Eatonton, Georgia
Im confused on 320.23 A . I have an attic space with with permanent stairs. It is made with roof trusses called attic truss. the attic is 34 ft wide but the trusses only have a 7 ft open space down the center. It seams by the code section that every conductor ran perpendicular to the joists (bottom cord) has to be drilled or have protector strips. As you know on a roof truss there are so many braces u cant just walk or crawl everywhere. In the past I have kept my perpendicular cables over near the end of rafter where the crawl space is very low maybe 18" or less. According to the code it seams none of the cables can be on top of crawl space. The reason I have done this in the past an inspector told me one time it is okay within 3 ft of the end of rafter. Was that wrong . I know about the 7 ft rule for fasten overhead.
