mmarro
- Pittsburgh, PA
Should I use insulated ground?  Also, what is the proper wire size for this type of application?
So, are you an electrician in training and you are going to wire a hot tub? I would be very careful here.I am going to look at the job this afternoon, but from what I spoke to the homeowner about yesterday, she stated that the hot tub was inside.
Again, is this a hot tub or whirlpool? I've never installed a hot tub in a house.
Probably not but I have wired 2 hydomassage tubs, in the same house, that required 220v.Oh, I just saw the 220v mention in the OP! It probably won't be a Hydromassage Bathtub!
Yes 220V is requiried when the tub has its own water heater.....
Hopefully this will be permited and inspected.
