So a box is buried under insulation. You can remove the insulation, work on the box, then, get this...... it's gonna blow your mind...................... you can put the insulation back where it was. What a concept! Whooda thunk it.
NOWHERE does any code state you are prohibited from putting the insulation back where it originally was.
This is the same as opening the door to a mechanical room, accessing a box, then closing the door when you're done.
