tonype
- New Jersey
Remodel and flip home - "Builder" claims work was performed by a licensed electrical contractor, but my feeling is that he did the work under someone elses license (since he was in the middle of replacing a breaker when I got there) - I see alot of this happening (the licensee is nowhere near the job).
At any rate, terminal bar contains oxidation corrosion (see photo) and there are 3 instances where the new circuit bare grounding and grounded neutral conductors share terminal bar screw.
The panel is also a ca. 1973 Square D - most ID stickers are missing - only reference a panel enclosure of QOBW20M100. Building has already put in one tandem, and is planning a 2nd; however, I question if this panel can accomodate tandems - does any one have old references on this?
http://i15.photobucket.com/albums/a352/TonyPE/P1160916_edited-1.jpg
http://i15.photobucket.com/albums/a352/TonyPE/P1160918_edited-1.jpg
