jetlag
- Eatonton, Georgia
Stand of brackets work fine on multi gang nail on boxes because the box clamp holds the cable so it cant back out past the the sheath when device is pushed in the box.  But on a single gang a 14/2 cable will slide back in the stand off bracket . 314.17 c exception states the cable must be secured with in 8 '' of the box.. I dont consider a stand off as securing the cable, it only supports it . I try to avoid the stand offs as much as possible , I can come down both side of a stud and have 2 cables under each staple , then drill thru the stud at the box and have 4 cables, with 2 in each end of box .  Thanks for any comments about the brackets not " securing " the cable to framing member.
