robert pitre
 - Houma,la
were in the Nec 2008 codes is the refence for this:-?
			There is a requirement for any receptacle that is outside of the house to be GFCI protected by one, and now(08' code) with a bubble cover.
.........Or is this a test question?![]()
If so, it's a poorly written one.
Has anyone attempted to run power tools after installing a GFCI in a garage? I had to switch to a non-GFCI outlet to run my radial arm saw, also for a tile saw because the GFCI kept kicking out. Yes it was a new GFCI and I have used it since for other purposes.
Considering that all the cord and plug connected power tools on a construction site function fine with GFCIs I think it is clear that both your tile saw and radial are saw have electrical issues that need to be fixed.
(Sorry Dennis, I posted before I read your post)
If this were the case wouldn't the saw trip a circuit breaker also?
not a problemIwire said:(Sorry Dennis, I posted before I read your post)
The kind of pump i am talking about is a (service station) pump or dispenser.
in article 514, If i am 18" away and 18" above grade it ok to installed a receptacle at that point? or 18" above grade and 20' away? or what?:-?
