- NE Nebraska
- EC
If an electrician attempts to work on the equipment then that probaly would void the warranty as we are not appliance repair persons.
Most manufacurers suggest getting an electrician to make sure the equipment is installed correctly and to code because the repair people are not licensed ( qualified, insured, ect. ) to do this.
If you just install the equipment then you are not opening it up. You should install useing the manufacturers instructions ( and all applicable codes ).
Many appliance repair people are not very good with electrical problems. There are common problems they see a lot and fix them easily but give them something they haven't seen before and they start replacing components until it works or call me after they have more money in parts than the appliance is worth.
I have many times told customers that the reason a GFCI trips is that there is a fault in a refrigerator or freezer. Appliance man says there is nothing wrong with it, I usually have to find the problem myself to prove that I was right and they were wrong, otherwise they think I'm supposed to get rid of the GFCI which I will not do. Appliance repairmen do not understand GFCI's and think if the appliance works on a non GFCI circuit that the GFCI is at fault.
