i see 404.4, thanks, but i thought somewhere it stated a distance. i thought it was 6 feet.
thanks again
i am trying to find in the code where it states the distance a switch can be located away from a tub
any help
thanks as always
any help
thanks as always
any help
thanks as always
It actually is, IMO given all other factors.The water in a bath tub is safer than water in a hot tub ? Nope but thats NEC for you
Yup, for a bathtub you only need the width of say one electron separating the switch from the tub's edge.
Who writes the NEC?
OK , please tell us how.......
Whirlypools and hot tubs and such have grounding & bonding requirements. Your run-of-the-mill bath tubs and showers don't.
And just how does that change anything ? Most hot tubs are fiberglass and if anything is an insulator. If you somehow touch live electric while in a bath tub your very likely dead unless you have a working gfi.
Neither is safe with electric in reach
MOST tubs may be fiberglass, but I'm still a believer of cast iron, so that's what I have. But there's no bonding and/or grounding of my cast iron tub, is there? So I have NO additional protection against shock.
But I put in a whirlypool, and it's GFCI protected, and it's bonded, and all this other stuff that my cast iron tub doesn't. So if you're saying all this additional stuff doesn't protect me, why is it all required?
Will agree the PH is likely bit differant. As far as conductive i rather dought that will change much in getting shocked. If you are so much as standing on a wet floor your already set up for a bad shock. That is why we want them outdoors.Jim it has more to do with the chemicals in the water of a hot tub. This makes it more conductive.
