busman
- Northern Virginia
- Master Electrician / Electrical Engineer
I've got a kitchen renovation that has an existing multiwire circuit for the dishwasher and disposal.  Was planning on a duplex receptacle, but the disposal isn't listed for cord and plug.  My plan was the following:
Place a 1900 box under the sink and add an extension ring that will extend into the cabinet. Run a cable from the extension ring to the disposal and put a receptacle on the RS cover for the dishwasher. Any better ideas? Photos.
I guess I could do all this with a plastic box in the wall, but for some reason, I'm not crazy about romex cables poking out thru the wall finish and cabinet back. There's also the problem of cabinet installers not cutting a big enough access hole that you can get to the flush mounted box and remove the cover. The extension ring would insure a big enough hole and provide good access for future changes. Thoughts?
As always, thank you.
Mark
Mark
