handy10
- western suburbs, chicago
I would imagine about 24,859 miles because at that point you will likely have reached 360 degrees of bend.
If you suspend 5' above the earth, it would be 31.4' longer.
How many straps should i order ? Stainless steel for the runs over salt water ?I have skimmed over many of the logistical issues.![]()
Does that take topography into account?If you suspend 5' above the earth, it would be 31.4' longer.
I could run a 400' vertical riser with 500 mcm, 4" rigid conduit, without a junction box, and be code compliant (it depends what material you use, job specs aside)![]()
My boss had me looking for this answer back before I had the internet to help. He thought it was 100' but I never found anything to back that up. Guess this turned out to be a cold case I can close.
I suggest that you look at 300.19 and Table 300.19(A) Spacings for Conductor Supports.
If fish tape is usedhow long is your fish tape? realy someone told me 300 ft. years ago
