mark32
- Currently in NJ
A customer wants to install an outdoor sub panel an inch from the corner of his house. He is also having his a/c compressor, which is just around the corner from where this sub is to go, relocated to within 6"+ - to the right of the to be installed sub. (A/C unit will be wall mounted and owner plans on leaving the disconnect in it's current location which would no longer be within sight of unit) I believe the location of the panel would be compliant considering there is nothing to the left of the panel but a breaker lock back at the main panel should be install for the a/c circuit. (I believe the disconnect is just a pull out type) Correctamundo yes?
