qcroanoke
Sometimes I don't know if I'm the boxer or the bag
 - Roanoke, VA.
 - Sorta retired........
Is a Burndy ground rod clamp rated for two wires? Got turned down on a rough-in today and all he wrote was install ground clamps correctly! Pray tell what is correctly. I pulled the #4 from the panel to the first ground rod and continued on to the second ground rod actually just went through the clamp and on to the next. wire was not cut,was not doubled up on the ground clamp. Am I missing something? Is there a certain way that the wire has to go through? I think I may have just used the screw to tighten up the wire. Should I have used the other side?
