matt_mackay
- Zion National Park, Utah
Hi all,
Just wanted to make sure I'm correct in my thinking.
I have a main distribution panel on a pole outside next to the meter. Conduit run from that panel to a building approx. 30' away to a fused disconnect on the outside of the building. From there conduit run to a distribution panel inside the building feeding lights, receps, etc. They ran 4 conductors ( 2 hots, 1 neutral, and 1 ground from the panel on the pole to the disconnect and then to the panel inside the building. My question: shouldn't there be a ground rod or a ufer installed at the disconnect located on the building?
