jwelectric
 - North Carolina
It is not an untrue statement but it is hardly a complete statement.
It is voltage, it is current, it is time as Brian pointed out and I bet other factors as well.
Again it is not an either / or type question.
The question
What would be an intelligent responce?
It aint the voltage, it's the amps that kills ya.
The answer
This is true. It is not the amount of voltage that kills but the amount of current that kills.
If 100millamps passes through the body it could be fatal at 120 volts or 25,000 volts. The voltage is variable but the current is all but fixed at 100 milliamps. This means that it is the current that kills not the voltage.
The resistance of the body is a variable. Under normal conditions the average resistance of an average male would be between 3 to 5 thousand ohms, but a hard working person on a hot day could be a little as 300 ohms but the amount of current is still 100 milliamps. Once again it is the current not the resistance that is the key to the effects.
The amount of time is a variable. Be it one nanosecond to a couple of seconds but the amount of current is the same, 100 milliamps. If in one nanosecond the current reaches 100 milliamps it could be fatal. If at two seconds the current doesn?t reach 5 milliamps a GFCI device will not open. Again the amperage is what is doing the damage.
I agree that voltage has to be present for some amount of time but unless the current is enough to cause death then it will not be fatal. The key being the amount of current and everything else is variable.
Therefore it is not the voltage, it is not the resistance of the body, it is not the amount of time but it is the amperage that does the damage.
Yes the amount of voltage, resistance of the body, and the amount of time is proportionate to the amount of current but it is the current that does the damage and everything else is variable.
