AK GUY
- juneau, AK. USA
Opinions on requirments to have AF's installed following changing of the load center ie, upgrading service
This type of installation is where AFCIs make the most sense, even though they are only required on new installations.
If the panel is installed with AFCIs and the older wiring and devices are fine, then ther should be no issues. However, the AFCI will pick up the faults (if any) of the older wiring and devices. This should be explained to the customer to let them know that the AFCIs will provide safety, but may cause more work ($$$) due to faults in the older wiring.
