jumper
 - 3 Hr 2 Min from Winged Horses
Very few houses here don't have fule fired appliances. New energy code doens't allow electric heat so. Even our "all electric" houses had FAU's installed.
Got it. Thanks.
Your 2nd line shows your concern, or lack of, for someone's safety & benefit. You proved my point that Big Brother would rather a person stay at a safety level of 1 or 2 if he can't afford to get to level 10. I could get him to a level 4 or 5 and he would be much better off than he is. But you really don't care about him as much as your rule book. If I could follow you around day to day, I'm sure I would hear you exhort plenty about safety. Go polish your horn.
I am not on a high horse, I am pointing out a situation and being assaulted by a bureaucrat that can't stand for "the system" to be examined.OK, time to get down off of your high horse. The code is what it is, if you don't like it get involved and try to change it, in the mean time if you want this person to have a Cadilac in place of a safe working Kia, then furnish it to him on your nickle, otherwise do the best you can and sleep well knowing you did what you did or didn't do.
Roger
Wow, John must have a hell of a right hook to span the USA.
I never said I would not comply with the law. I get along fine with all the inspectors in my area. I didn't start this thread to bash inspectors, just to point out the shortcomings of the laws & codes.
It is the authorities that want him to have a Cadillac, not me. That is exactly my point. He has a Yugo now & the law requires him to bypass the Kia, going up to the Cadillac.
Maybe in CA it works that way but most everywhere else if you take out a permit for just about anything you get a RE tax increase. And some places it is a double whammy. They have tax rate caps that any kind of improvement nullifies.As for the tax increases you guys keep talking about, repair and maintenance do not increase your taxes nor do doing interior improvements. Usually the only things that set of the tax assessor is adding of square footage and built in pools.
GFCI's are a proven technology with a measurable standard. AFCI's...???I don't care if you examine the system, I don't even care if you bash it, it's not my system, I didn't create it, it was around 35+ years ago when I got in the trades. What I care about is when every one wants to examine and bash, but not take the time to fix it. I remember when we all hated GFCI's and now every contractor worth his salt using them as an upsell....
They weren't in 1978.
I heard that a lot of the old GFCIs would still feed power out if they failed and if they were miswired line/load.
How about you give me a device that works and can be tested to a measurable standard before it becomes mandatory.Give AFCI's a chance.
They weren't in 1978. Give AFCI's a chance.
