mivey
Well of course there are two waveforms (just counting the neutral to ungrounded ones) as we have a three-wire circuit.Well, that's pretty much what I've been saying from the beginning........On the same waveform, a phase shift is a time shift. Are you somehow suggesting that with a single-phase, center-tapped, common-core transformer, you are getting two different waveforms on the secondary from a single waveform on the primary? When you change (ῳt) to (ῳt+180), it's either two waveforms or an added time shift. Those two points do not occur at the same point on a waveform.
We are not modeling the transformer but we are modeling what leaves the transformer. That is not quite the same thing. Consider the unbalanced case and how the neutral current makes the currents in the two winding halves unequal.Mathematically it is fine to say that cos(ῳt) = -cos(ῳt+180), but it is wrong to extend this mathematical interpretation into the absolute function of a center-tapped transformer. Yes, it works when you have a pure and perfect sinusoidal waveform, but that does not mean the transformer's function can be defined that way. This is why I have been trying to get you to understand the difference of putting a non-symmetrical wave into the transformer.
It's not that I am obsessed on non-symmetrical waves. I am trying to use that as a means to get you to see than there is a difference between your mathematical model and how the transformer is defined. You can mathematically model the transformer any way you wish, but some members here have made assertions that their mathematical model is absolute, which therefore defines the transformer instead of just modeling it.
