mivey
I've updated the picture in photobucket but it may take a while for their cache to clear.If you can't edit your posts I can do it for you.
Thank you for your kind words. As I said, it reflects my day job.I, for one, am quite impressed with your knowledge. Not because I am judging your pedigree, but because I have read many of your posts over the years and am quite sure you know what you are talking about.
It was an attempt to educate. A failed attempt it would appear.Don't let Rick goad you.
On the whole, I don't deal with the power transmission field although power electronics is used there too for HVDC transmission.When someone has remained within a single sect of the industry for 40 years, there may sometimes be a propensity to forget that there are many other sects that make up the industry as a whole. Evidence to this is forgetting that transformer theory spans many more areas than just power transmission.
Indeed they do.It is not important that transformers can and do exist for pulsed inputs.
Economics dictate that that power frequency transformers operate as close as they can to saturation.The quiescence of the input signal between 180? and 360? will reduce the overall core flux in the transformer and you won't automatically reach saturation as long as you are not already operating near saturation.
Economics dictate that that power frequency transformers operate as close as they can to saturation.Rick Christopherson said:The quiescence of the input signal between 180? and 360? will reduce the overall core flux in the transformer and you won't automatically reach saturation as long as you are not already operating near saturation.
Evidently not fine from your POV. Although it is actual real world stuff. How many such circuits have you designed that are currently in operation in numerous applications doing a real world job?That's a fine posting with a lot of information.
What non symmetry?What is still missing is any discussion on the non-symmetry ramifications of your 180? phase shift.
Finegood. Go for it.When your input waveform is not perfectly symmetrical about pi, it becomes very obvious that inverting the signal is not the same as phase-shifting it 180?. That is the topic at-hand. Can we stick to that topic?
No, that's because you have been avoiding the topic asked. You assert that there is a phase shift in the transformer. Looking at a non-symmetrical wave will dispel this. I think you know that, and that is why you keep avoiding the topic.Evidently not fine from your POV.
Yes. Yes I do, and that is the topic we have been trying to cover for a few days now. It is not a phase shift, and examining a non-symmetrical waveform will reveal this. It is nothing more than a magnitude reversal. A minus sign.The obvious explanation for anyone who has done any work in this field is that the two 120V-N voltages are 180deg apart. Do you have an alternative (and credible) explanation?
This argument began when you stated that there was a phase shift.
The 180? phase shift exists only because you have hidden the negative sign caused by reversing the polarity of the power source's reference.
You're arguing for the sake of arguing. Read a little more carefully. It was stated in post #3, refuted in post #21, then Beoseker stated it as an absolute in post #22, and we were off to the races, so to speak. Was this really the most important contribution you could make to this discussion?Ummm....The first mention of "phase shift" occurs here (post #25):
Read a little more carefully. It was stated in post #3, refuted in post #21, then Besoeker stated it as an absolute in post #22, and we were off to the races, so to speak. Was this really the most important contribution you could make to this discussion?
Please try to tone it down a bit with the condescending comments.
Yeah, condescension - at elast this is what I've been accused of - is my domain and I resent intrusion:lol:
First off David, 180? is a phase shift.In order for Vl to have a magnitude of 240V, we know that the voltage angles of Van and Vbn must have 180deg between them.
I'll repeat what I said earlier so you don't misunderstand. I am NOT telling you that you cannot use your 180? tool. What I am stating is that it is not correct to claim that the system "must have" the 180? shift. When you do that, not only are you in error, but you force everyone to use your tool regardless whether they want to or not.
