T
T.M.Haja Sahib
Guest
The accuracy of your thinking is amazing.My salutations to you.Your second diagram solves the problem in favor of you except that it is very costly and my objection was based on the simple but less costly first diagram and in that case I am also right.Below is 480sparky's diagram Sahib refers to.
Sahib, don't use this method if you want a MWBC to run all the way to the last receptacle outlet. Instead, use the method shown in the other diagram with this noteable modification: Install a regular two pole circuit breaker. Install a GFCI receptacle at every receptacle location.
Again, Sahib, in this second diagram directly above these words, Install a regular two pole circuit breaker in place of the GFCI breakers. Install a GFCI receptacle at every receptacle location.
You will have a MWBC all the way to the last receptacle, AND, all of the GFCI receptacles will work perfectly.
