tonype
 - New Jersey
Don't think so.Photo shows several neutrals twisted together in the panel before each one individually connects to the terminal bar - just looks odd View attachment 6230
It looks terrible and if you ever had to disconnect one it is a bear to deal with. Nothing against code but Dennis' Rules would chew you out for that install. :lol:I don't see any issues, not even a "workmanship" issue.
I think it looks a lot better than where they are just stuffed in. I would also chew a guy out, but only because to took longer to do it that way.It looks terrible and if you ever had to disconnect one it is a bear to deal with. Nothing against code but Dennis' Rules would chew you out for that install. :lol:
Just stuffed in looks sloppy also but there is a fine line between perfection and doing a nice install. My work is similar to thisI think it looks a lot better than where they are just stuffed in. I would also chew a guy out, but only because to took longer to do it that way.
	You have a cable feeding the panel and there are two conductors from breaker 1&3 that seem to go the lugs at the bottom of the panel.
besides, where is the workmanship manner?
I wonder if they untwisted the end to connect them to the bar? Or did they shove all three or four of them in the same hole?
If the split base is more than the top 2 breakers than I agree esp. with the configuration. You could however add breaker ties and be compliant.This is a main panel.
The top 8 breaker positions are all labeled "Mains" (guess they were intended for (4), 2-pole breakers, though (6) single-poles and (1) 2-pole are in those positons). The 60-amp "Lighting Main" services the bottom breakers.
I also think, based on this configuration, that a main is needed.
Oh I bet there are some jurisdictions that won't allow it but that is perfectly compliant in my opinion.nice work on the 2nd pic. is the romex exposed to physical damage even if its neat?
I am sure someone would argue this job as non compliant
