T
		T.M.Haja Sahib
Guest
A standard sounds more like an Annex to a code (if the code references it) than a code.
In my opinion,if the code mentions about a standard,then that standard is as enforceable as the code itself.
A standard sounds more like an Annex to a code (if the code references it) than a code. It sure looks like the NEC wins in a contest - but you would know better than I.![]()
Properly cited, I agree; however, the NEC does not reference NFPA 13, with respect to grounding electrodes. Conversely, NFPA 13 subordinates itself to the NEC via Sections 2.1 and 2.2.In my opinion,if the code mentions about a standard,then that standard is as enforceable as the code itself.
You?ve never seen me say either one.How many times have we read on this site that the NEC is a permissive document?
How many times have we read on this site that the NEC doesn?t say we can?t then we can?
Again from the Regulations Governing Committee Projects, a ?Code? is an elevated Standard; i.e., it?s still a Standard....
A Standard on the other hand is not a permissive document but instead it is a mandatory document.
Again from the Regulations Governing Committee Projects, a ?Code? is an elevated Standard; i.e., it?s still a Standard.[/QUOTE]
From you link
Code - A standard that is an extensive compilation of provisions covering broad subject matter or that is suitable for adoption into law independently of other codes and standards.
NOTE: The decision whether to designate a standard as a ?code? is based on such factors as the size and scope of the document, its intended use and form of adoption, and whether it contains substantial enforcement and administrative provisions.
Standard - A document, the main text of which contains only mandatory provisions using the word ?shall? to indicate requirements and which is in a form generally suitable for mandatory reference by another standard or code or for adoption into law. Nonmandatory provisions shall be located in an appendix or annex, footnote, or fine-print note and are not to be considered a part of the requirements of a standard.
Your point?
I sincerely appreciated it....
I thought it might be appreciated by someone.
I agree.I will not close this thread but I think it has run its course.
I agree.RogerI will not close this thread but I think it has run its course.
And since both sides are in agreement we will close the thread before things change.Me too .
Am I required to have one?
I just thought it would be nice to post the two definitions so someone would not have to read the entire document to find them.
