ptonsparky
Tom
- EC - retired
Hooking equipment up to temp power source we find a 10 hp compressor that has run for years @ 480v. Coil on contactor is 240v. Is there enough impedance on this type of coil that it doesn't matter? SQ D.
Shortened response:If you're asking if a 240V coil work on 480V then the answer is don't even think about trying it.
So what exactly is it that you're asking?We replaced the existing with the proper coil. And changed the overload heaters to reflect the amperage @ 480 vs 240.
Why, how did it work for so long? Any thing I miswired takes only seconds for the smoke to escape.
They just don't make stuff like they used to......
Or, it did have the proper size coil and wasn't marked correctly.
Still don't think you have explained the problem or even if there is one.Why, how did it work for so long? Any thing I miswired takes only seconds for the smoke to escape.
What was the applied voltage coil previously and what was its voltage rating?
What is the applied voltage coil now and what is its voltage rating?
Me too, I'd sure as hell smoke it if I wired it up...?:huh:
Did you ever meter the voltage when the coil sucked in to see if it stayed a true 480?
Applied v 480 coil rating 240 before
Applied v 480 coil rating 480 now
Can you think of a third way to write that?![]()
C'mon, give the guy some slack. Maybe it's just me, i can live with that.
