- Windsor, CO NEC: 2023
- Hospital Master Electrician
Interesting. How do you measure the impedance of a coil?
My only guess:
The control transformer probably didn't have enough capacity to fry the coil. As a result, the current through the coil probably dropped the transfromer voltage enough that the coil didn't fry, and the transformer probably didn't die either.
That means it may have been a very lucky balance - a transformer with a higher VA capacity probably would have fried the coil, one with a lower VA capacity, and the control transformer probably would have fried.
Steve
No control transformer.
How easy is it to remove the coil from the contactor? It may have been swapped to expedite a repair at some time in the past.
In that case the contactor would have dropped out due to low coil voltage much lower than 240V........
I didn't say it dropped that low. I was thinking the 480V contol voltage dropped somewhere closer to the 240-300 volt range. Just enough that it didn't fry the coil.
But that blows that theory.
I think that's a very possible explaination.
Did you actually measure the voltage across the old coil?
By the way, I had a lighting rep come in yesterday, and he plugged his 12V LED lights into his 24V power supply. I can guarentee he didn't have the same luck this coil seems to have had![]()
Well.Does each coil measure 709 ohms?Coil measures 709 ohms, via text pict that my help just sent. If I could figure out how to forward & post them I would. I am TC at times.
Congratulations!You have found a super coil able to withstand 480V above its rated 240V....
