There were no disparaging remarks in what I wrote.
Is not a disparaging remark?Can you not get it through your thick head
I find that remarkable.
Fair point.Does the range example I have often cited, have a common conductor between the two loads? Is it the neutral of the voltages?
Don't believe I ever posted that. Others might have.Other than to say Vbn = -Vnb?
Would you like me to re-submit without the line to line load?Although now that you bring it up. You posted a nice graph and current values for a 3-load circuit. I don't think I saw your 2-load results?
From my days in education all those decades ago, I seem to recall that it was often presented that way with the sum of the currents being zero per good old Gustav K.David and I discussed his results, which brought up the issue of a node with two currents entering but none leaving.
Hundreds, going on thousands, of posts and I have yet to see a single one saying these circuits, like the rectifiers you are rightly proud of, cannot work. I said there appears to be a displacement based on the way you choose to reference your wiring (not the actual wiring itself). Choose a different reference and there appears to be no displacement. Are you saying my notations, showing 0? displacment, on your diagram, are incorrect?
I would recommend a 15 gauge pneumatic nailer to help pull the baseboards tighter to the wall.I'm also a moderately practical fellow.
To this:
in a weekend. Including the painting, the laminate floor, a new commode (not shown), the plumbing for it etc. The taps and waste for the basin were done the following weekend.
Simple point. I don't do just theory.
What are they?That there are a huge number of circuits in operation that work as a result of that 180deg displacement.
I'm afraid it is your reasoning that went astray from the building.
It doesn't matter if 'N' is grounded or not - its' voltage is 0V. So is L1's, so is L2's, etc. Voltage is the electric potential difference between TWO points. Saying N has 0V is meaningless because you are only referencing ONE point is the system.
You are still missing that fact that a vector has MAGNITUDE and DIRECTION. You are ignoring the DIRECTION component. The voltage vector from L1 to N has the same DIRECTION as the voltage vector from N to L2. So if the voltage vector from L1 to N is 120<0V, then the voltage vector from N to L2 is also 120<0. The sum (not the difference) of these two vectors gives the voltage from L1 to L2. Vl1-n + Vl2-2 = 120<0 + 120<0 = 240<0.
It should also be clear that if the voltage vector from L1 to N has a value of 120<0V, then the voltage vector from N to L1 would be the reverse of it. In other words Vn-l1=120<180V, which is the same as -120<0V.
You may also have appeared in the above completed work with thumbs up..I'm also a moderately practical fellow.
This:
To this:
Subsequent to that pic, I screwed them to the wall. That way, when/if I need to get them off, I can do so without damage to either them or the wall.I would recommend a 15 gauge pneumatic nailer to help pull the baseboards tighter to the wall.
See post #227.What are they?
More likely with a book.You may also have appeared in the above completed work with thumbs up..![]()
You are grossly mistaken.Whatever AC voltages you depicted there and elsewhere are all RMS values,not instantaneous.The present discussion is about instantaneous voltages and currents on 240V/120V single phase system and how that would lead to relevant RMS values of voltages and currents.........See post #227.
We alone, have used this arrangement for huge numbers of power electronic applications.
Mistaken? How so?You are grossly mistaken.
If so,please explain in brief how in phase instantaneous voltage and current, and out of phase instantaneous voltage and current are utilized in the operation of the device.Don't you think I might might be more likely than you to know what we have built and shipped?
Hold on a minute......lets' back up a few......If so,please explain in brief how in phase instantaneous voltage and current, and out of phase instantaneous voltage and current are utilized in the operation of the device.
See post #227 (which was the circuit arrangement).
So what exactly is it about my post #228 that you think justifies you accusing me of being grossly mistaken?You are grossly mistaken.
You mistook RMS values for instantaneous values and falsely asserted that 240V/120V single phase system is a two phase system on the basis of its RMS voltages designation 120V-0-120V and tried to justify it through your unrelated post #228.So what exactly is it about my post #228 that you think justifies you accusing me of being grossly mistaken?
I absolutely did not. In fact, you should have been able to determine that from the waveforms I posted.You mistook RMS values for instantaneous values
I have asserted that, for a 120-0-120 system, Van and Vbn are mutually displaced by 180deg. I continue to assert that simple fact.and falsely asserted that 240V/120V single phase system is a two phase system on the basis of its RMS voltages designation 120V-0-120V.
By Van and Vbn do you mean instantaneous voltage vector values?I have asserted that, for a 120-0-120 system, Van and Vbn are mutually displaced by 180deg. I continue to assert that simple fact.
Post #288 was a simple answer to your question "What are they?"tried to justify it through your unrelated post #228.
There is a big fat clue in the 120-0-120. I'll let you ponder that for a while.By Van and Vbn do you mean instantaneous voltage vector values?
Please do not try to mislead,The center tapped transformer in your post # 288 is entirely different from the center tapped transformer under discussion here in that your transformer secondary windings were wound in the opposite direction,one clockwise and the other anticlockwise so that 180 degree shift is possible.Post #288 was a simple answer to your question "What are they?"
A simple statement of the facts as they are.
We have supplied huge numbers of PCBs with this 50V-0-50Vcircuit arrangement.
The two halves HAVE to be in anti-phase for it to work.
You are too reluctant even to say a yes or no to continue the discussion along this line.......There is a big fat clue in the 120-0-120. I'll let you ponder that for a while.
