T
T.M.Haja Sahib
Guest
To your questionSomething, or nothing depending on the load - or lack thereof.
But I might be grossly mistaken.
Now, what's an instantaneous vector voltage?
Please answer it.
A voltage sinusoid can be created by projecting a vector with magnitude equal to V and revolving anticlockwise at angular velocity w on to the Y axis with respect to time on X axis.The position of a point on the sinusoid is determined by the position of the revolving vector at that instant.
Now back to the discussion.
Suppose the two loads on the secondary are 1 ohm each.Then the instantaneous current in the top hot conductor is 120A and that in bottom hot conductor -120A i.e the current flow thorough the two loads is in the same direction.So the voltages are also in phase.So if we take any other instantaneous values of the two voltages and calculate the currents,we will find the currents flow in the same direction and hence the two voltages are in phase.That is why it is called single phase supply.
