mivey
How else does one interpret what you posted?I know it has been a lot of posts, but did I miss where someone said the reference must be based on the physical, except for the group talking about the physical connection of an oscilloscope?Wasn't my premise at all. Mivey would just like it to be my premise. Twas his interpretation.Yes, you missed it. That was pfalcon's premise.
For sinusoidal waveforms:
1) Establish a common reference frame for both waves to be tested.
For the residential issue, only AB or BA presents a common reference (1). AN, BN, NB, NA exclude other portions of the coil that we wish to test. Therefore those references cannot establish synchronization or phase.
"Exclude other portions of the coil" sure sounds like you are saying the reference frame must be based on the physical. Specifically, it sure reads that you have said that in order for the reference to be valid, the physical portion of the coil containing the reference voltage must overlap the physical portion of the coil containing the voltage to be tested.
Pray tell: how else would you expect this to be interpreted?
