 - Mission Viejo, CA
 - Professional Electrical Engineer
At the very best, all you've done is accuse your colleagues in "oscilloscope-land" of refusing to accept that "single-phase" is indeed "single-phase." I don't know about the other three, but your head is apparently stuck so far up your oscilloscope, you can't tell the difference between synchronism and phase. I cautioned you a long time ago against letting a model color your understanding.Mivey's position is well know, gar is in agreement with me, and Besoeker has just posted:
"And, if you have two voltages displaced by 180deg, they are not in phase."
All you have done with your identity is show that a sinusoid shifted by 180 degrees is equal to its inverse. Without the minus sign it would not be an inverse. So polarity is relevant.
Now look at the phasor diagram:
V2 = 120Vrms @ 180 <-----------N----------->V1 = 120Vrms @ 0
How can you say these two waves are in phase? You could go through the CRC Math Handbook and not find a way.
My last post to mivey has an alternate "real world" experiment that doesn't rely on an oscilloscope to illustrate the difference - you should try it, as well.
