One diode is connected Van anode to cathode in series with the load. The other diode is connected Vbn anode to cathode in series with the load.
That's how it is. No effective about it.
It requires the 180deg displacement to make it work.
Two voltages displaced by 180 deg cannot be in phase.
They are thus different phases. So, more than one phase.
Found the diagram, post #1004?
This is the classic full-wave rectifier circuit using SCRs.
Node a is X1,
Common/neutral is the junction between X2 and X3.
Node b is X4.
Polarity dots could be added to nodes X1 and X3.
The rectifiers conduct at 180 degree intervals to minimize ripple.
Van and Vbn are in antiphase.
Did I get it right Bes?
