- Mission Viejo, CA
- Professional Electrical Engineer
Would you care to post a relevant definition of phase? All the formal ones posted so far indicate that, as it applies to "Why is residential wiring known as single phase?", direction is irrelevant; it's relevant to synchronism, not phase.Not a red herring. As long as you limit the discussion to voltage, Mivey wins. Because he's playing scarecrow to Dorothy. He's dropping a negative on you. But if you're gonna insist on voltage anyway, then model the equivalent DC circuits for T=90 and T=270. That should point out his inversions. He's using his neutral reference convention to measure both directions at the same time and claiming it's only one direction.
ex. If I face south the south pole is forward. If I face north the north pole is forward. Therefore both poles are "away" from me and therefore in a positive direction. Both are +(half a world away).
Is power a vector or a scalar? If it's a vector how did you determine it? A cross (vector) product would result in no power at all when current and voltage are "in phase" since sin (0) is zero and it would be a moment anyway. If it?s the result of a scalar (dot) product, it has no direction and so is useless as a ?direction? reference. If it?s a simple scalar constant x vector quantity product, then you must assume either voltage or current has no direction. Since most would agree at least current is a vector quantity, it means voltage has no direction and is useless as a "direction" reference. How would you analyze an ?open circuit? when there is no current flow at all?
The only "references" necessary for phase as it applies to "Why is residential wiring known as single phase?" are the voltage functions' period and "when did the function
