I don't see that happening. It is the whole approach about trying to call a phase something that it is not that I take issue with. I understand what you are trying to say, but I think your approach is wrong. There are other ways to skin that cat. Even so, you will eventually run into some of the same problems that exist with Jim's "line-to-line" method.
What it will eventually boil down to is that we call them what we call them because of convention and because the label fits some of what we see or fits the most common use. I promise you that any "rule-book" type attempt is going to be marred with exceptions. That is why I said if you are going to attempt some rule-play, Jim's method is much simpler and works for the majority of cases.
But for the record, I would prefer a definition that is consistent with the definitions, descriptions, examples, pictures, or whatever you want to call what our industry accepts as a common understanding. That understanding is consistent in all of the texts I reviewed before I quite because of the preponderance of the evidence (a couple of dozen or so?). Here is some wording that should be clear:
In-phase (AC waves): The condition in which AC waves are in step with with each other at all points such that all of the following are true:
1) the zero values of the waves occur at the same point in time
2) the maximums of the waves occur at the same point in time
3) the minimums of the waves occur at the same point in time
4) the ratios of the wave values at the non-zero points produce a positive number
