I don't think the case of filing the tub with water makes it a continuous load. It has to be under typical use that it runs at full load for 3 hours or more. DO you always fill your tub with water before using it?
Anything can be left on for a long time by accident or have a special long first time startup sequence. Just like things can occasionally get sprayed with water, that doesn't necessarily make it a wet area.
