Rick Christopherson
Well, you immediately jump off on the wrong foot, so there is not much to be said with the remainder. The only reason you can claim that a phase shift does not correspond with a time shift is because it is not truly a phase shift. It is an inversion that can be mathematically represented (if one chooses) as a phase shift if and only if the waveform is periodic and perfectly sinusoidal.Then let's talk about facts. With a transformer, one does not have to have a time shift to have a phase shift.
This is not a function of the transformer. This is a function of the waveform entering the transformer. Therefore, your claim that the existence of a center-tapped transformer results in a phase shift, is patently false. It is only the existence of the sinusoidal waveform that may be represented this way.
