- Wisconsin
- PE (Retired) - Power Systems
This displacement was obtained by using identical generators but simply rotating the shaft of one 180? relative to the other.
Sorry but just more purposful misinformation.
You physically created two independent time shifted voltages, which is not the same as the same as a single center-tapped output.
If you cannot create a center-tapped generator output then I guess it was a waste of time asking for the plot.
I have repeatedly refused to participate in discussions of sources other than a center-tap.
