encoreman
- Austin, TX
We are installing a new communications system for a customer. They specified that the system should be three phase. We are getting 480 volts from the customer's system which turns out to be three phase. We have already ordered the "shelter" that will house the communications equipment. I see our choices as these:
1. Connect a single phase transformer to the three phase system.
2. Replace the internals of the breaker panel with three phase guts and balance our load as best we can (the single phase air conditioning is already installed).
The transformer is already on site which means we may have to operate 120/208 on the single phase panel with reduced capacity (I'll have to see if there is enough power to handle it).
The customer may be able to balance their load if we run in single phase mode.
My question is:
Will this cause the customer any problems? Especially if he doesn't make any attempt to balance the rest of the load?
Thanks!
Jack
My question is:
Thanks!
Jack
