Jaggedben:
Yes, I agree, PV wire definitely
does not equate to conduit, but it does allow me to sleep easier.....
(The inspector may simply say ok to it. It is a level of protection above USE-2.....it still does not meet the letter of the Code)
Good to hear your experience also with the lack of enforcement on groundmounts, Jaggedben. I don't see this groundmount fencing or inaccessibility provision enforced often. Which means never. All the more frustrating when it DOES come up. Say...when you are done building!
The more i talk about this groundmount accessibility issue vs 600VDC issue the more I see a possible solution:
an expanded metal screen (mesh).
Made of alumium.
NO disimilar metals. NO UV degradation of cheap plastic.
It could be TEK screwed to the underside of aluminum rails. This would be underneath ALL wiring. That would cover 80% of the underside of an array! THen maybe an ACME wire clip could slide onto the lip of the module frame at the array edges, and attach the mesh! Anyways.....wouldn't even be visible.
Am i gonna do this? NO. BUt thinking.......
Hot off the plate: Thanks, the fact that Sunpower has use-2 cabling is prob'ly why i never see use-2 module leads......
