BillK-AZ
 - Mesa Arizona
Definations
Definations
A series or parallel collection of photovoltaic (PV) cells, sealed in an assembly is a photovoltaic MODULE.
A set of PV modules, connected together, is a PV PANEL.
The collection of the PV panels in a PV SYSTEM is a PV ARRAY.
Breaks between or within CELLS are internal to a module.
Most of this discussion concerns connections between modules with the normal module interconnection cables.
A related conduit problem is how to deal with the micro inverters that have rather large AC connectors on the tails and/or on the factory assembled parallel connection cable. Any conduit that would pass the connector can not terminate to the thin and relatively small inverter, so a conduit solution is difficult.
			Definations
