T
		T.M.Haja Sahib
Guest
The authors took the electric field of surface charge on the ideal conductors for calculation of the Poyntic vector without showing how it may be calculated, though the other factor the magnetic flux density may be calculated as shown in the paper. They simply assumed without validating it that this the electric field of surface charge becomes equal to the axial field intensity in the resistence of the circuit.What they did not derive was either referenced in links or considered common knowledge. Perhaps you should read some of the references.
But if you have found any relationship for the electric field of surface charge in any reference just as the magnetic flux density has as shown in the paper, please produce it here to support your contention.
The quantitative relationship is already available in terms of circuit variables: voltage and current.Perhaps you have derived some quantitative relationships to support your opinions? If so, please share with the rest of us.
Energy passing the circuit=voltage*current*time.
