mark32
- Currently in NJ
A buddy changed his mind from installing a spa to a Mitsubishi split a/c unit. The a/c will be set about 15' from the house, I already have 1"pvc running out there which lb's into the house and into the panel a short distance from there. So what are you guys doing out there as far as powering the blower unit? I've read bits and pieces on here but nothing too complete on the topic. Maybe swap out the lb for a j-box and pipe up the wall with the blower power (Coming from the a/c unit). What about the t-stat cable, I could just reclassify the control circuit and use thhn when I pull it from the house to the condensing unit, right?
